#23167 - 07/09/10 03:33 PM Lanpaks limits
Sammy Offline
Loc: Summerland, B.C. Canada
I generally have my Ledger, Receivables, Payables, and Inventory open at the same time and our receptionist will have Receivables, Payables and sometime Inventory open. This has never been a problem. Yesterday I did all of the updates and since them I keep getting the following message: "All Adagio Lanpak lincenses are already in use. This application cannot be started." Why is this now a problem, We have paid for two licenses and I understand that allows us 12 modules open at the same time. Is there something I need to do?
#23169 - 07/09/10 03:45 PM Re: Lanpaks limits [Re: Sammy]
Hi Sammy,
It may be that some of your updates require a newer version for Lanpaks that what you currently have installed.
First, open any Adagio program and go to the Help menu, and from there pick About. On the screen that appears, towards the bottom is displayed the number of Lanpak Licenses in use. It might say something like '0 of 5' or '3 of 10' or '1'. This will tell you the number of lanpaks this application recognizes. If you see '1', that means that no lanpaks are recognized, and thus are considered old. If you see 'x of y' then some lanpaks are installed and recognized by the program.
Second, from the Help menu choose System Status. This will run the CHKSYS.EXE utility. When the initial process is complete, click the Lanpak versions button to list all installed lanpaks of any version. This will indicate whether all of your lanpaks are up to date or if some/all of them are old.
You may need to install upgrades for your lanpaks. I believe an upgrade notice for version 9.0C was recently sent out.
#23172 - 07/09/10 04:48 PM Re: Lanpaks limits [Re: Softrak Support]
Sammy Offline
Thanks for the response. I can not see what could be old as I updated everything to current. I will go through the system check and make sure all the files are correct and otherwise get back to you.
0 registered (), 414 Guests and 1 Spider online.
14646 Topics
