#22714 - 06/11/10 12:17 PM Gridview Formula Help
Can anyone tell me how to write a filter formula that will accomplish this:
Instead of saying, {Item #} = "SA EX"
I want it to say, {Item #} contains "SA EX"
Are there wildcards I can use or another method?
#22715 - 06/11/10 12:22 PM Re: Gridview Formula Help [Re: SusanTennier]
Hi Susan,
Use the FIND function. Search for one piece of text ("SA EX") within some other text ({Item #}), starting at a particular place (1 for the beginning of the item #, a different number if you don't want to search at the beginning of the item #).
The result will be 0 if not found, or an integer if found, representing the character position where it was found. Do a filter that looks for the result of this formula not equal to zero.
Information for using the FIND function can be found in the Help file.
#22723 - 06/11/10 02:53 PM Re: Gridview Formula Help [Re: Softrak Support]
Michael Mulrooney Offline
The MID function should also work if the "SA EX" is always in the same position in the Item #
4 registered (Salman, Softrak Support, Lauren Stief, 1 invisible), 69 Guests and 2 Spiders online.
14567 Topics
