#22469 - 05/26/10 08:46 AM ICv 8.1B Transaction History Glich
Treasure S. Offline
Loc: Winnipeg, MB
It has come to my attention when doing an item inquiry that the transaction History function is not working correctly.
I'll select the item that I need to check, ie: 10-widget-25
then Select the Transaction History tab. Key in beginning and ending dates and select all transactions then hit Load.
My history of my Receipts since I've upgraded in April do not appear. Only when I uncheck all and select only receipts will the transaction of all the receipts appear for the particular item I'm checking.
Now I'm also using POA v8.1A so it maybe something to do with the info getting from POA to IC. Anyway, it's something I'd like fix down the road. Thanks
Edited by Treasure S. (05/26/10 09:01 AM)
#22470 - 05/26/10 09:02 AM Re: ICv 8.1B Transaction History Glich [Re: Treasure S.]
Treasure S. Offline
Loc: Winnipeg, MB
I was just talking to Doug Dickie and he solved my problem.
thanks Doug
For Anyone else having this issue you just need to make sure you put zzzzzz in the ending field of vendors if you have that coming up as your default. Then the receipts come up.
Edited by Treasure S. (05/26/10 09:09 AM)
#22471 - 05/26/10 09:03 AM Re: ICv 8.1B Transaction History Clich [Re: Treasure S.]
Treasure:
Most likely you have a Vendor range that goes from <blank> to <blank>. This means exclude all vendors. As every receipt from PO would have a vendor attached to the record you are effectively excluding all receipts.
The solution is to change the vendor range from <blank> to <zzzzzz>. This would include all vendors.
1 registered (Tanya_Belanger), 188 Guests and 74 Spiders online.
14625 Topics
