#22354 - 05/19/10 08:27 AM Lanpak difficulties
Matthew_Prime Offline
Casual
Loc: Ottawa, ON
Hi Support,
I'm attempting to access a data set on my local drive. All Adagio applications, including Lanpak, are installed on my local drive. I'm using an NFR package, so I have 2 lanpaks for my use.
Here's the problem: for reasons I cannot understand, I am occasionally blocked from accessing my data because apparently I am using all of my Lanpaks. Normally, this would make sense if I were working in two separate modules concurrently, but this happens even when zero modules are open. I am not being interrupted by server crashes (again, all modules are on my local) shut downs or restarts or - to my knowledge - any other such issue.
What can be done to get around/fix this issue? Am I not properly closing my modules, perhaps? I've had this problem with other programs, where the system did not recognize that a user had logged off and blocked others from accessing the respective data sets.
Any help is appreciated. Thanks.
Update: our local techie just passed through and told me Lanpaks on the local drive are a no-no and that a full re-install is the safe way to go.
Edited by Matthew_Prime (05/19/10 11:05 AM)
#22364 - 05/19/10 01:39 PM Re: Lanpak difficulties [Re: Matthew_Prime]
There should only be one install, on the server.
2 registered (Warren Karges, 1 invisible), 123 Guests and 4 Spiders online.
1869 Members
14601 Topics
