#22234 - 05/11/10 09:00 AM
Changing a Balance Sheet Acct to Income Stmt Acct
Harold Piche
I did a "Close Income/Expense Accounts" for FY2010, and I printed out the Trial Balance to ensure all accounts were closed. There were 4 income accounts that did not close because they are set at "balance sheet" instead of "income statement". I tried to switch it, but it won't allow me. What do I do next?
#22266 - 05/12/10 08:28 AM
Re: Changing a Balance Sheet Acct to Income Stmt Acct
[Re: Steve Schwartz]
Harold Piche
Well, I loaded my backup. Yet it still says I cannot change it because it might have a balance in prior year (it does not), current year (it does), or future year (it does not).
Exact error message is: This account has an Opening balance or a Closing amount in a Prior Vear, the Current Vear or Next Vear. The account type cannot be changed.
Can I just do a Journal Entry into an account that is an Income Statement, and then those accounts would have a zero balance and then could I just delete them? There are 4 accounts.
#22299 - 05/13/10 05:32 PM
Loc: Surrey/Langley BC Canada with ...
A number of our clients have had a similar experience.
We think the problem started when the Next Fiscal Year process was run. I believe that this is when the "Opening balance or a Closing amount in a Prior Year, the Current Year or Next Year" entries are generated by GL 9.x, based on the Account Type, at that time.
This is notably different from Accpac Plus for DOS, which did not have the improved benefits of a Soft Year-end, but only used this setting when the "Close Year Function" was run. Personally, I would like to see Adagio display a warning when "Create Next Fiscal Year" is selected. After all, historically, for MANY years, Accpac Plus for DOS users have checked the Account Type as part of the Year End Process immediately prior to running the "Close Year" function.
If this is your first Year-end with the wrong Acct Types, you might be able to unpost the GL Batches posted after the "Create Next Fiscal Year" process was run, Restore from the prior Backup, Correct the Account Type, Create your Next Year and Repost the Unposted Batches accordingly.
Hope this helps, good luck!
Kerry Gullins IOS Consulting Group Inc. Phone. 778.819-1467 kerryg@iosgroup.com www.iosgroup.com
#22300 - 05/13/10 07:34 PM
[Re: KGullins]
All you need to do is set up the Account groups and enforce them and the DIC will complain about the improperly assigned account types before any year end process is done.
0 registered (),
236
Guests and
Spider online. |
14644 Topics
