#22022 - 04/30/10 07:38 AM Year End Processing
Rhonda Offline
New Guy
I am a relatively new user of Adagio. I performed a Period End in Payables for March 31 but left the default date on the system as yesterday's date (29-Apr-10). I then performed the Year End function and opened up a new Payables for 10/11. However, instead of the first Batch number defaulting to #1, it was #6.
I had processed 5 batches in April that were for 09/10. Is there a way to override the numbering system to begin at #1 or is it fixed due to the 5 batches that were done in April? They do not exist anywhere in the 10/11 Payables.
#22033 - 04/30/10 10:09 AM Re: Year End Processing [Re: Rhonda]
Hi Rhonda,
The date that a Period End is performed would not affect how the batch numbering is defined. Rather, when Year End Processing is performed, the batch number should be reset to 1.
Year End could not have been run if you had any open batches. So one of two possible scenarios is the culprit:
1) 5 batches did not get cleared from the batch status files, meaning the next batch you create would be #6.
2) The batch status files did clear correctly, but batch data files numbered 1 through 5 that shouldn't have existed were there, so that when you created a new batch, the first 5 numbers were skipped and #6 was used.
In short, there isn't a way to override the batch numbers, unless you are willing to restore data from an old backup, determine the cause of the numbering issue, and re-do your year end.
If you print/preview the batch status report for all available batches (found under the Reports menu), perhaps this will give a clue as to how the first 5 batch numbers were handled.
2 registered (Tanya_Belanger, chinmook), 200 Guests and 2 Spiders online.
14625 Topics
