#21571 - 03/31/10 03:21 PM Printing Cheques
Julie Offline
Stranger
Loc: Vancouver, BC, Canada
Hi
When I print a cheque the preview only showes that I'm printing one cheque but then 2 pages actually print and the first page has a dimond shape in the top left corner.
My tech guy said it sounds like a possible "code" problem.
Can anyone help?
Julie
#21579 - 03/31/10 04:38 PM Re: Printing Cheques [Re: Julie]
Hi Julie,
Can we confirm the Adagio program you are using - Adagio Payables or Adagio Checks - and the version? This can be found from the Help menu and pick About. At the top will be the program name, version and 6-digit release date.
Are you printing checks to a laser or a dot-matrix printer?
What printer driver are you using?
If you are printing checks with MICR encoding to an HP laser printer driver using PCL6 emulation, try getting a different driver that uses PCL5e emulation instead.
Do other check specifications have this same issue or just the one you typically use?
Does print preview show one page, but when you print the check for real it creates two pages? This could be an issue in the print job being created. Can this behaviour be replicated on a different printer?
This is not something we are aware of.
#21581 - 03/31/10 05:31 PM Re: Printing Cheques [Re: Softrak Support]
Seems more like a problem caused by using a POst Script printer driver. Given that this has worked up until now what has changed?
