#21456 - 03/23/10 11:36 AM re-installing data path
Kim A Offline
Casual
Loc: Prince George, BC
Hello. As a result of ongoing computer and server issues I have reinstalled Adagio directly onto my hard drive. (first time I have had up to date modules in 13 months!) I entered the data path to the drive on the server that we used previously ( and were my data still is)and it worked for all modules except Invoices 8.1B. This module tells me that the data is already being used and that I need a new path. Any suggestions? I do have an invoice batch I had started that I want to bring in. Does Invoices use a different data source than the other modules? Ledger, Receivables, and Payables
Thank you
#21459 - 03/23/10 12:19 PM Re: re-installing data path [Re: Kim A]
Hi Kim,
Firstly, I assume when you indicated that you reinstalled Adagio directly to your hard drive, this means you installed the programs locally onto a workstation, rather than a network location. Is this correct?
When loading the Invoices 81B program, the data can be identified when browsing folders by a QIGLOB data file, and it will be found in the same data directory as any other program data such as Ledger or Receivables. When you started Invoices, did you click Open or Create? Hopefully 'Open'. If you clicked Create and data already existed, you would get an error that data already exists - similar to what you saw and reported.
If you are clicking Open and are getting an error, please post the exact wording of the message you see, so that we can assist.
#21471 - 03/23/10 04:17 PM Re: re-installing data path [Re: Softrak Support]
Kim A Offline
Casual
I kept trying and 3rd time is the charm!
thanks
14630 Topics
