#21425 - 03/18/10 01:15 PM Purging reconciled cheques in BankRec
How do I purge reconciled cheques in the BankRec module when I am no longer interested in them?
#21426 - 03/18/10 01:54 PM Re: Purging reconciled cheques in BankRec [Re: Retired_Guy]
Period End under the Maintenance menu, however I must warn you that it does not work the same way period end does in other modules. BankRec does not respect the 'retain history for xxx days' set in the company profile. All transactions are cleared to the period end date set so, for example, if you wanted to keep the last 365 you must set the period end date back that amount (whereas AP & AR you can use the true period end date and the date to purge history up to is calculated based upon the number of days to keep history set in their comapny profiles).
Something the develop will hopefully fix.
#21428 - 03/18/10 02:09 PM Re: Purging reconciled cheques in BankRec [Re: Douglas Dickie]
Thanks Doug. I wanted to show the class in Dominica how to get a question answered on the forum. smile
0 registered (), 209 Guests and 1 Spider online.
14666 Topics
