#21267 - 03/04/10 09:46 AM AP to GL transaction interface
Is there any code available to move the second (detail) description entered with an AP invoice over to the general ledger transaction? If not, could you add a spec code to get at this information?
#21269 - 03/04/10 09:54 AM Re: AP to GL transaction interface [Re: Douglas Dickie]
Hi Doug,
There is no 'Detail Description' spec code in Adagio Payables to send this information to the Ledger batch, as there is with Receivables and the %dds code.
Suggestion noted.
#21295 - 03/09/10 10:26 AM Re: AP to GL transaction interface [Re: Douglas Dickie]
Actually, on further investigation, there is a way to get the detail description across to the expense account debit.
If the company profile option allows the edit of the detail description, then the code "%des" in the user defined option for the Ledger interface will move the detail description, rather than the header description.
We will update the documentation to reflect this.
#21300 - 03/09/10 11:35 AM Re: AP to GL transaction interface [Re: Retired_Guy]
Andrew:
If I recall correctly this particular user wants both the header and detail description to be in Ledger. I believe your options results in one or the other.
1 registered (Softrak Support), 70 Guests and 0 Spiders online.
14567 Topics
