#20922 - 02/09/10 03:43 PM Invoice Designer-Missing Company Info
Jackie Wong Offline
Casual
Loc: British Columbia
We just installed AR V9.0A. Lots of new specs codes for Statement Designer. I have just printed Invoices in AI V8.1B and notice Company data is missing from Invoice Spec. Please help
#20923 - 02/09/10 04:00 PM Re: Invoice Designer-Missing Company Info [Re: Jackie Wong]
Hi, Jackie,
Open your SpecDesigner and select File | Open Template | All specification codes. Note the spec's title store in the Spec Options. Then SaveAs the spec to your data folder using your company's 3-character data extension.
Try previewing the invoice again using this spec. For each code on the All spec for which the invoice contains data, you will see the code, spec section and invoice data on the previewed spec. This is a very useful tool to help determine what codes should be used to produce results in a particular section of a spec document.
#20933 - 02/10/10 09:12 AM Re: Invoice Designer-Missing Company Info [Re: Softrak Support]
Jackie Wong Offline
Casual
Hi there:
Thank you, such a simple solution!
Jackie
