#20841 - 02/03/10 08:37 AM Complete System Re-Install
Lucas Offline
Loc: Vancouver, B.C., Canada
For various reasons I need to completely reinstall my Adagio system on a different partition (well, a different drive altogether).
Is this as simple as backing up my data, moving it to the new partition and then pointing the installer to the new space? Are there some recommended steps for this procedure?
Any help would be great. Thanks!
#20844 - 02/03/10 02:32 PM Re: Complete System Re-Install [Re: Lucas]
Hi Lucas
The data files can be copied and pasted whereever you want (on the network if you want to share them), independent of where the program is installed. So your line about backing up the data is unclear.
As for copying the \Softrak folder and it's subfolders, I believe you can do that if you are going to use the same mapped drive letter as you used before, and you will not be using the server as an Adagio workstation. Otherwise you will have to reinstall from the .exe files (either CDs or downloads), and you will need to know your codes.
0 registered (), 63 Guests and 3 Spiders online.
