#20699 - 01/27/10 11:22 AM OE Discount
We've never used the discount field on the Total tab in OE, but it might serve us well in certain situations. I tested it out today with some sample data and it worked except that it doesn't print on the Invoice anywhere. It prints only the sub-total, tax and total. For example we sell an item for $20 and give a $5 discount. The subtotal still says $20, but the tax is .75 and the total is $15.75. Although the calculations are correct, there is no mention of the discount anywhere on the invoice and no explanation of how the subtotal of $20 translated to a total of $15.75. I assume that I would have to edit the spec sheets to show the discount somehow? The other question I have about this method is does the discount go to a GL account or does it just come off sales?
Another thought is if I could add an item code called MC Discount and enter the discount amount. This would work very well except that OE won't allow us to enter negatives.
Any suggestions/ideas on an easy method for accomplishing either of these ideas? Basically what we want to do is give customers a credit towards specific purchases for specific products. We don't want to issue a credit on their account because it would have the potential to be used for non-qualifying purchases. When they purchase a qualifying item, we want to give them the credit amount instantly.
#20702 - 01/27/10 11:44 AM Re: OE Discount [Re: SusanTennier]
Hi Susan,
Use the "All Fields" specification to determine what field number you need to print on your specification to make the invoice numbers meaningful.
#20707 - 01/27/10 01:05 PM Re: OE Discount [Re: Retired_Guy]
I figured out that I can use the OE's misc charges to add a negative amount. I also added it to the spec sheet. It seems to be working so far! Thanks.
0 registered (), 209 Guests and 1 Spider online.
14667 Topics
