#20527 - 01/15/10 07:25 PM Setting default location code in O/E
Taylor Offline
Loc: Alberta Canada
Using O/E 8.1C (090731)
I have just created a new order entry for the sole purpose of generating picking tickets. When entering a new order: On the Header screen, the location is empty. If I try to go the the Details screen, a message "A valid location code is required" comes up. I can key in a location code; but in the past, it has always defaulted.
I think I have set up a default in Maintainence - Define Order Entry Template. Under the Order tab, for Location the Enter on New and Skip Field are left unchecked, and the Default is set to "AB". I have set up "AB" as a location code.
(I have had this problem before in a different O/E data base. It seemed to happen after we did the upgrade in early September. I didn't worry about this one because I was only going to be using it for a few more weeks.)
So my question is, how do I get the location code to default? Is this "my" problem, or an "Adagio" problem? I do not have the latest hot fix. I've been hoping that a service pack would be coming soon.
Any help would be appreciated. Thanks, Linda
#20528 - 01/16/10 09:34 AM Re: Setting default location code in O/E [Re: Taylor]
The 'Define Order Entry Template' under Maintenance is the default for creating new "user group security".
You need to modify each security group and change the template there.
#20529 - 01/16/10 07:18 PM Re: Setting default location code in O/E [Re: Douglas Dickie]
The location can also be set on the customer or the ship-to address, if desired.
#20545 - 01/18/10 07:44 PM Re: Setting default location code in O/E [Re: Softrak Support]
Taylor Offline
Loc: Alberta Canada
Thank you Douglas. Using your idea fixed the problem.
Linda
2 registered (Douglas Dickie, Samuel Kopstick), 151 Guests and 2 Spiders online.
14668 Topics
