#20508 - 01/15/10 07:13 AM POA error adding system variable in spec
EdW Offline
Loc: Langley
POA 8.1A 091029 returns the error - Access violation at address 0042C37C in module IR.exe - whenever a system variable field is added to the extended PO spec. i.e. we want to add something like "Page 1 of 1" to the PO form.
Updated with the latest System Updater (Jan 05 2010) - error happened before updating as well - thought this might fix it.
Windows Server 2008 envirnonment with Windows XP Pro and Windows 7 Pro workstations. Tried it on both desktop o/s - same error.
Is there a workaround or fix?
ed@cascadiasystems.ca
Langley BC
#20514 - 01/15/10 11:43 AM Re: POA error adding system variable in spec [Re: Softrak Support]
Hi, Ed,
The error you are receiving isn't related to your adding a system variable to a spec, it occurs each time you File | Close or 'x' out of the specification.
I've reported this to R&D for you.
As you may know, the spec editor within PO is different than the one used in other Adagio modules. We are working to make the program more Adagio-like; however, this will take time.
In the meantime, I recommend you use File | Save whenever you've made any changes to a spec. After, you can either File | Close or 'x' out of the spec and, when prompted to save your changes again, say 'No'. This way, you won't receive that access violation error.
0 registered (), 347 Guests and 2 Spiders online.
14673 Topics
