#19741 - 11/21/09 09:42 AM Gridview View for text string in a range of accts
Lyndon_Olfert Offline
Loc: Winnipeg
Each year our client's auditors ask for a schedule of remuneration and travel costs for key staff.
How would you go about creating a Gridview view that would query the user for the range of accounts you wish to search for a particular text string? Example: I wish to search all accounts from 8000 to 9999 for the text string "Lyndon"
This search would be on the Ledger database.
Lyndon Olfert, CPA, CGA, CAFM
#19745 - 11/22/09 08:58 PM Re: Gridview View for text string in a range of accts [Re: Lyndon_Olfert]
Hello Lyndon:
Create a View using the "G/L Posted Transactions" table.
Create a filter using the following syntax:
AND(
TRIM({Trx Acct}) >= QUERYSTRING("Starting Account", "1000"),
TRIM({Trx Acct}) <= QUERYSTRING("Ending Account", "9999"),
FIND(UPPER(QUERYSTRING("Search for")), UPPER({Trans Description 1}&{Trans Description 2} ),1 ) > 0
You will be asked to enter 3 pieces of information:
-Starting Acct
-Ending Acct
-Text string
The text string search is case insensitive and searches both Description 1 and Description 2.
#19746 - 11/23/09 05:01 AM Re: Gridview View for text string in a range of accts [Re: Bruce Gardner]
Hello Lyndon:
I should add that the example above assumes GL 9.0A or B. If you are using 8.1, remove the reference to Description 2.
#19747 - 11/23/09 07:30 AM Re: Gridview View for text string in a range of accts [Re: Bruce Gardner]
Loc: Winnipeg
I am impressed. It worked on the first attempt! Thanks Bruce!
Is there a way for it to not be case sensitive? I remember Andrew mentioning that you can force the results of a search into Upper Case somehow.
#19748 - 11/23/09 07:31 AM Re: Gridview View for text string in a range of accts [Re: Bruce Gardner]
Thanks Bruce,
I was just waiting until I powered up my laptop, but you beat me to it!
#19749 - 11/23/09 07:39 AM Re: Gridview View for text string in a range of accts [Re: Retired_Guy]
doswalt Offline
Loc: AL
FIND formula above uses the UPPER() formula so it finds everything.
David
#19750 - 11/23/09 07:40 AM Re: Gridview View for text string in a range of accts [Re: Lyndon_Olfert]
Hi Lyndon:
The search doesn't care whether you use upper or lower case. You'll see that the UPPER() function is used to convert both what the user types in and what is contained in the 2 Description fields. That way apples are compared to apples.
I should have said "not case sensitive" rather than "case insensitive" earlier. I thought of that at the time, but it was late & I was tired!
#19753 - 11/23/09 08:25 AM Re: Gridview View for text string in a range of accts [Re: Bruce Gardner]
Loc: Winnipeg
That is what I thought the "UPPER" meant. Thanks again
0 registered (), 80 Guests and 1 Spider online.
14527 Topics
