#19627 - 11/18/09 10:25 AM Invoice Module - Duplicate Inv. Numbers
Karen Offline
Karen
Loc: Pine Brook, NJ
I don't know if this has been addressed before (even perhaps by me????), but we're getting duplicate invoice numbers in our invoice module. They're not the same customers, but the duplication of numbers is confusing. Is there a setting that needs to be checked off to avoid this from happening????
Thanks in advance,
Karen
#19630 - 11/18/09 11:28 AM Re: Invoice Module - Duplicate Inv. Numbers [Re: Karen]
Hi Karen,
In the company profile for Adagio Invoices is a place to set the next invoice number and whether it auto-increments. Whenever a new invoice is created, the document number assigned there will be used and then incremented for the next invoice.
If after creating an invoice, someone goes back into the company profile and resets the 'next invoice number' back to one already used, then indeed a duplicate invoice number will be created. Also, if the invoice number is not 'locked' - another company profile option - then the entry person could edit the invoice number used and over-ride it with one that has already been used.
When copying or restoring invoices, there is an option to 'increment document number'. If you don't select this then the invoice number from the original document is copied to the new invoice - thus a duplicate unless it is changed.
In order to prevent duplicate numbers as best as possible, enable the option to 'lock' the invoice number from being edited, and only grant access to the Company Profile for the user(s) that should have it. And when copying or restoring invoices, always leave the 'increment document number' option enabled.
#19636 - 11/18/09 02:08 PM Re: Invoice Module - Duplicate Inv. Numbers [Re: Softrak Support]
Have you checked your OpLocks settings? This might also cause the problems you're seeing.
0 registered (), 346 Guests and 4 Spiders online.
14627 Topics
