#1918 - 02/11/02 04:35 PM Re: QR for Windows workstation installations
Hi Mike
It's been a long time - hope all is well!
This is most likely related to the drive that was indicated as the 'Report tables' drive when the report was first created. Because the station that originally created the report could be mapped to a different drive, there are a couple of things you can do to remedy this...
1. CREATE A NEW CUSTOM REPORT
 In QRW, create a new custom report. On the 'Select program for report' screen, choose the 'Edit Company' button.
 In the section 'ACCPAC Data’, choose the ‘New’ button.
 Click the ‘Browse’ button
 Find the Data Drive and directory where the ACCPAC Plus data resides that you want to use QRWIN with.
 Click on one of the xxGLOB.dat files (AR for example) & click OK.
 Click OK if all the information displayed in the next couple of screens is correct, then from the Select Program for Report window, select the AR version that is installed.
 Select a table from the list (say, Customer Information), then click OK.
 Insert a couple of fields on your report, then save the report as ‘Test.rpt’ or something.
If that does not work...
2. CHECK AND/OR EDIT THE CRW.INI FILE
 Exit QRWIN.
 Using MS Explorer, go to your C:\Windows directory.
 Click on the crw.ini file to open it.
 Find the section that is entitled [ACCPAC.DLLInfo]
 Scroll down until you find the line “ACCPACPath=”.
 You must ensure that this line contains the drive letter where your ACCPAC programs and \QRASP directory are located. If it does not, edit the line to display the correct drive letter, and save your changes.
 You can now exit Explorer and go back in to QRWIN and try again to print your reports.
Hope this helps!
#1920 - 02/11/02 05:24 PM Re: QR for Windows workstation installations
That's great! Glad to hear it!
