#18385 - 08/20/09 11:39 AM clearing historical transactions
Kim A Offline
Casual
Loc: Prince George, BC
I am using acc/pay 8.1A. I wanted to delete a vendor that has had no activity since Feb 27/02. I am unable to delete as there are historical transactions. How do I go about clearing these transactions so that I can delete the vendor?
Thank you.
Kim
#18387 - 08/20/09 11:49 AM Re: clearing historical transactions [Re: Kim A]
Hi Kim,
In Adagio Payables, either Period End or Year End will clear transactions from history older than a certain date, but only if you select the option to do so. This does not selectively purge history for certain vendors, but for all vendors.
The next time you run Period End, first set the number of days you want to keep history in the company profile. Then select the 'delete history' checkbox when running period end.
If the history doesn't clear, then there is a problem with the data. But that would not be a typical scenario and things should work just fine.
#18391 - 08/20/09 03:11 PM Re: clearing historical transactions [Re: Softrak Support]
Kim A Offline
Casual
thank you - I will do this at month end
Kim
0 registered (), 42 Guests and 5 Spiders online.
14571 Topics
Max Online: 1211 @ 12/01/25 01:32 PM
