#1839 - 01/08/02 01:19 AM Adagio Newbie
gglatz Offline
Loc: Winnipeg
I am installing Adagio OE, IC into an existing Plus OE, IC (6.1b) environment.
I am assuming that in order for the order history to work the day end must be run from Adagio. What happens if someone inadvertently ran it from the Plus product ?
Some people will slowly migrate to the Adagio OE.
#1840 - 01/08/02 12:38 PM Re: Adagio Newbie
Hi gbglatz,
You are correct that Adagio OE would have to be used to move the purged documents into the Adagio OE history files. If someone inadvertantly ran Day End from Accpac OE, everything still would be OK unless they chose to delete the documents 'older than X days' towards the end of the process. Should a user choose to purge, then those documents are irretrievable, short of restoring from a backup.
Adagio OE and IC will work simulataneously with Accpac Plus OE/IC 6.1B. As you have noted, there are some processes that will have to be adhered to (such as doing Day End in OE with Adagio) if you wish to write to the data files unique to Adagio.
Best of luck with the install! I'm sure everything should go just fine.
Softrak Support
0 registered (), 117 Guests and 3 Spiders online.
14653 Topics
