#18375 - 08/19/09 02:19 PM Ledger 9.0B sign-on
Lyndon_Olfert Offline
Loc: Winnipeg
Your manual states that you can customize the ADS.INI to eliminate the option of remembering the username and password by adding the lines:
[Options]
RememberUser=0
RememberPassword=0
It would appear that there is no ads.ini file if the client is not in a network environment using a lanpac. Changing the ledger.ini file does not seem to work to eliminate the remembered username and password.
Am I correct?
Lyndon Olfert, CPA, CGA, CAFM
#18376 - 08/19/09 02:37 PM Re: Ledger 9.0B sign-on [Re: Lyndon_Olfert]
Hi Lyndon,
The legder.ini would not do anything as you have noted. Only the ads.ini file; if it doesn't exist, then use Notepad to create it in the \softrak\system directory.
#18377 - 08/19/09 04:02 PM Re: Ledger 9.0B sign-on [Re: Softrak Support]
Loc: Winnipeg
Thanks, that worked as advertised!
2 registered (Douglas Dickie, 1 invisible), 233 Guests and 2 Spiders online.
14672 Topics
