#18357 - 08/18/09 05:07 PM Column header
Eva_Froese Offline
Adagio Expert
Loc: MB
If I do a departmental print, how can I show the column header as a department description instead of the department number?
Edited by Eva_Froese (08/18/09 05:08 PM)
Eva Froese
eva@choicetech.ca
#18358 - 08/18/09 05:17 PM Re: Column header [Re: Eva_Froese]
Michael Mulrooney Offline
=TRIM(DEPARTMENT(0)) give you the Department Code or * as a result.
=TRIM(DEPARTMENT("100")) will return the description for department 100
If E6 = 100 and Department 100 description is East Coast then
=TRIM(DEPARTMENT(E6)) will return East Coast
#18359 - 08/18/09 05:21 PM Re: Column header [Re: Eva_Froese]
Hi Eva,
The formula =DEPARTMENT(1) will return the description of the department selected in the toolbar or by the Department Print function, and can be used in the top of each statement or any cell as desired. Use TRIM (as Michael indicated) if you need to get rid of leading or trailing spaces.
You have asked about putting the department description as a column header. Certainly the above will work, as will Michael's examples - just wondering how this fits with the Departmental Print function? Usually column headers indicate that you want to compare multiple departments, something that the Departmental Print function is not set up not do - generate a single statement comparing all selected departments.
#18372 - 08/19/09 11:15 AM Re: Column header [Re: Softrak Support]
Eva_Froese Offline
Adagio Expert
Loc: MB
The idea is to be able to select any combination of departments to report on. The number and selected departments the reports are run for could be differenct every time.
Eva Froese
eva@choicetech.ca
#18373 - 08/19/09 11:21 AM Re: Column header [Re: Eva_Froese]
Then =DEPARTMENT(1) is what you want for your Heading
Edited by Michael Mulrooney (08/19/09 11:22 AM)
14617 Topics
