#18121 - 08/05/09 11:44 AM Ledger - Balance Line Missing from Detail Listing
Jeffrey Marshall Offline
Loc: Vancouver
After doing the excel work around for the import issue, we got our batches entered into ledger we found an issue with the accounts detailed listing report.
At the end of the report the July report had the following lines:
Balance
Acount Net Change
Account ballance
Report Net Change
Report Balance
The Aug. report has the following:
Acount Net Change
Account ballance
Report Net Change
Report Balance
Anyway to get the balance line back?
Thanks.
Jeffrey Marshall
Jeffrey Marshall
#18123 - 08/05/09 12:14 PM Re: Ledger - Balance Line Missing from Detail Listing [Re: Jeffrey Marshall]
Hi, Jeffrey,
I'm using Ledger 9.0B(090713). I see all of the same lines as you saw when using Ledger 9.0A. I see these same lines when using the original release of GL9.0B (090430).
#18126 - 08/05/09 12:57 PM Re: Ledger - Balance Line Missing from Detail Listing [Re: Softrak Support]
Loc: Vancouver
Which file contains this report? I'm thinking the file may have been changed so if I can check the date stamp of the file in the 2 directories where I'm getting different results, because I'm seeing the different results using 9.0B (090713).I checked a test directory and it has lines:
Balance
Acount Net Change
Account ballance
Report Net Change
Report Balance
Wereas our current company data shows every thing except the final balance of the account listing on last page.
Jeffrey Marshall
#18142 - 08/06/09 01:27 PM Re: Ledger - Balance Line Missing from Detail Listing [Re: Jeffrey Marshall]
Loc: Vancouver
Still waiting to hear what file contains the detail listing report.
Jeffrey Marshall
#18145 - 08/06/09 01:40 PM Re: Ledger - Balance Line Missing from Detail Listing [Re: Jeffrey Marshall]
Hi Jeffrey,
It will be one of the ALLIST* reports depending on whether you are running multi-currency or not and whether you are printing it in extended form.
#18147 - 08/06/09 01:45 PM Re: Ledger - Balance Line Missing from Detail Listing [Re: Jeffrey Marshall]
Hi, Jeffrey,
There are many files that make up the report possibilities for the Detail Listing. For the version of GL9.0B you are using, they are:
Allistc_v2.rpt -- 1/05/2009
Allistc_mc_v2.rpt -- 4/01/2009
Alliste_v2.rpt -- 7/07/2009
Alliste_mc_v2.rpt -- 4/01/2009
Allists_v2.rpt -- 7/07/2009
Allists_mc_v2.rpt -- 4/01/2009
You should also check to see if perhaps, within your server's, your Softrak\Ledger folder contains a ModRP folder. It may be that you are running a modified version of a core report.
#18157 - 08/06/09 02:29 PM Re: Ledger - Balance Line Missing from Detail Listing [Re: Softrak Support]
Loc: Vancouver
Thank you very much. I checked both my test_softrak directory and softrak directory and the date stamps matched. Copied these file from test to live and final account totals is showing now.
Jeffrey Marshall
0 registered (), 197 Guests and 3 Spiders online.
1865 Members
14509 Topics
27 28 29 30 31
