#18007 - 07/27/09 08:16 AM POA - Item details moves Off Screen
When entering a Quick Receipt in POA, we enter the beginning part of the item code and down arrow to call up the Item Listing in that general area. For some reason unknown to me, the Window with the Item Listing goes off the screen on the left side so you can actually see the item codes. You can't pull it back or restore it. I have no idea why it's doing this or how to fix it. Does anybody know?
#18019 - 07/27/09 01:40 PM Re: POA - Item details moves Off Screen [Re: SusanTennier]
Michael Mulrooney Offline
You don't mention what version of PO you are using. For PO the title from the main form that has the date is preferred. Something like Purchase Orders for Adagio 8.1 (09-Apr-2009)
We have seen this happening when there are two screens and the "Document Detail Line" form is moved from one screen to the other, the finder is resized and closed and then the "Document Detail line" formed is moved back. You can try to fix this by moving the "Document Detail Line" to the left screen , the finder should be properly anchored and you should be able to see the item information.
#18058 - 07/29/09 02:24 PM Re: POA - Item details moves Off Screen [Re: Michael Mulrooney]
Hi Michael,
Thanks for your reply. I am using POA 8.1 (090619). I received a tip from Ryan to try resizing the window smaller until it is off the screen then hit esc. I'm not sure if that fixed it or it was another stroke of luck but it is currently corrected. I haven't tried your method above and not sure I understand it but will look again when the issue arises as it seems to periodically and will update this post.
#22503 - 05/28/10 05:00 AM Re: POA - Item details moves Off Screen [Re: SusanTennier]
Michael.. thanks again.. had to revert to this thread again for the same issue.
0 registered (), 200 Guests and 7 Spiders online.
14568 Topics
