#18025 - 07/28/09 11:47 AM Data Dictionary Exporter and Crystal Reports
Tony Martin Offline
Loc: Chatham, Ontario, Canada
Couple of odd results when using the output from the Data Dictionary Exporter to help in converting Crystal Reports for Receivables 9.0A:
1. In the 'Customer Notes Detail' table, the Exporter does not show a 'customer' field, but Crystal does and the record length seems to indicate it is still there.
2. The name of the customer table is 'Customer Information' in Crystal, but 'Customer Master' in the exporter.
Which is correct and should be used in reports and aliases (aliai?).
Tony Martin
Code 6 Programming
519.359.0918
#18027 - 07/28/09 01:24 PM Re: Data Dictionary Exporter and Crystal Reports [Re: Tony Martin]
Michael Mulrooney Offline
The information from the Data Dictionary Exporter can only be used for GridView, ODBC and OLEDB. These products use ADS32 and the dictionaries from ..\Softrak\Dict
You are using Crystal with the QRW tables that are from the \QRASP folder. In your case the correct table is the "ARW90 Customer Information"
#18031 - 07/28/09 02:12 PM Re: Data Dictionary Exporter and Crystal Reports [Re: Michael Mulrooney]
Tony Martin Offline
Thanks Michael.
Tony Martin
Code 6 Programming
519.359.0918
