#17753 - 06/29/09 01:18 PM Default A/P Cheque Spec
KNoel Offline
Loc: Ottawa ON Canada
We're using AP 8.1A (070919)
We have several different bank accounts with unique cheque specifications. Is there a way to make one of these the default specification that appears when you print/post cheques?
#17754 - 06/29/09 01:26 PM Re: Default A/P Cheque Spec [Re: KNoel]
Yes. If you edit the Bank, there is a 'Specifications' tab from which you can assign a particular check specification for printing checks. You also have the choice of choosing different specifications if you print checks from a manual check batch versus generating checks from the Print/Post Checks and Advices section ('system checks').
#17765 - 06/30/09 10:05 AM Re: Default A/P Cheque Spec [Re: Softrak Support]
KNoel Offline
Duh! How could I not think about checking the bank menu...
Thanks, problem solved!
0 registered (), 110 Guests and 0 Spiders online.
14599 Topics
