#17685 - 06/23/09 02:14 PM Gridview Row Height
Is there a way to increase the row height in Gridview? I can format the size of the text in each column (so it will be saved) but the row height doesn't grow with the text.
#17686 - 06/23/09 02:36 PM Re: Gridview Row Height [Re: SusanTennier]
doswalt Offline
Loc: AL
You can select the range of rows to change, then position the cursor on the row numbers until a little line appears. Then drag down to increase height.
This is one way and I'm sure there are others.
David
#17687 - 06/23/09 02:49 PM Re: Gridview Row Height [Re: doswalt]
Nice.. this works.. but is there a way to save the row height for the next person that opens the Gridview?
#17688 - 06/23/09 04:28 PM Re: Gridview Row Height [Re: SusanTennier]
Hello Susan,
Instead of changing the font size to accommodate everyone, just use the Zoom in (F11) / Zoom out (F12). This way the font size and the row height will increase/decrease at the same time.
#17717 - 06/25/09 07:38 AM Re: Gridview Row Height [Re: Softrak Support]
That's something else I didn't know. Thanks for the great viewing tip. However, we use these reports to print most often to PDF then send to our reps by email. The larger font and extra row height makes the report easier to read.
#17720 - 06/25/09 09:04 AM Re: Gridview Row Height [Re: SusanTennier]
Hi Susan,
Change the font size of the "Standard" style under Format | Styles.
#17725 - 06/25/09 12:52 PM Re: Gridview Row Height [Re: Retired_Guy]
Fantastic!!
2 registered (Brian_Shead, 1 invisible), 844 Guests and 9 Spiders online.
14568 Topics
