#17492 - 06/05/09 07:12 PM Invalid path to data dictionary error (AR9.0A)
David Cheng Offline
New Guy
Hi, I recently tried to update my client's Adagio Receivable from 8.1A (070603) to 9.0A (090511). The update was installed from workstation, no error during the update process. After the update finished, I ran AR9, it asked to convert database to the new version. Then an error message: "Critical Error: (1212) invalid path to data dictionary" popped up. The process stopped there.
The client has Adagio Ledge 9.0A and Adagio LanPak 9.0B installed beside Adagio Receivable. All of them are updated with the most recent service packs.
Data integrity check came up clean for the receivable database. I've tried uninstall and reinstall the update, but still getting the same error. Just wondering if anyone can help
#17493 - 06/05/09 07:22 PM Re: Invalid path to data dictionary error (AR9.0A) [Re: David Cheng]
Hi David,
Adagio loads dictionaries from the \softrak\dict directory, and a '1212' error is indicative of one or more required dictionaries being mis-dated or missing. Does your client use any other Adagio programs in addition to Ledger and Receivables?
To start with, check the file dates of the @R90AI.ssi and @R90AR.ssi files - these are the Receivables 90A dictionaries. If either are missing or have a file date different than March 19, 2009, this is the problem. You would need to get everyone out of Adagio programs, remove these 2 files, and re-install the Receivables upgrade.
I assume that when you mentioned that the integrity check was clean, you are referring to using Adagio Receivables 81A and a back-up of the data prior to conversion. This error is not related to the data.
#17494 - 06/08/09 10:25 AM Re: Invalid path to data dictionary error (AR9.0A) [Re: Softrak Support]
David Cheng Offline
New Guy
Hi, thanks for the reply.
my client only have Adagio Ledger and Receivable module installed, and the Lanpak that was required for the update
the file date for the @R90AI.ssi and @R90AR.ssi matches March 19, 2009. And the 2 files are located inside the \softrak\dict directory. I tried to remove the 2 files and re-install the Receivable upgrade, but it still gives out the same error
and yes, I was using Receivable 8.1A to check the data integrity
***Edited***
I tried to ran Receivable 9 Sample data, it prompted me for the following
EZFile Directories
Please confirm the location of required program files.
The currency file and task files are typically located in the Adagio \SOFTRAK\SYSTEM directory
I entered in the \softrak\system directory for both currenty and task files. After that, it gives out the same error message: Critical error: (1212) invalid path to data dictionary
Edited by David Cheng (06/08/09 10:41 AM)
#17496 - 06/08/09 11:22 AM Re: Invalid path to data dictionary error (AR9.0A) [Re: David Cheng]
Hi, David,
Problems with dictionary files that have taken on the date of an install usually don't show themselves until a subsequent install. It could be that your installs of LP9.0B or AR9.0A were just fine but 'triggered' a problem from an earlier install.
Please check the following files in Softrak\Dict and their dates:
@R80AI.xxi 4/25/2008
@R80AR.ssi 5/05/2008
@R80BI.ssi 6/23/2008
@R80BR.ssi 6/23/2008
You've already confirmed the dates of the two AR9 dictionaries are correct.
If any of the files is missing or has a different date, get everyone out of Adagio again, rename the file(s) and reinstall AR9 again. Always ensure an install is done from a workstation that is connected to the server via a LAN and not while logged onto the server itself.
Also, please ensure Ledger 9.0A is current (i.e. not earlier than 080402, later is good).
#17498 - 06/08/09 12:18 PM Re: Invalid path to data dictionary error (AR9.0A) [Re: Softrak Support]
David Cheng Offline
New Guy
the 4 files are all present in the softrak\dict folder, and the date matches. However, I did find the some of the files was dated on the date when Ledger was updated to 9.0A 080402). I renamed the files and reinstalled Ledger 9.0A (080402), the files now have the correct date. But Receivable 9 still gives out the invalid path to data dictionary error.
Edited by David Cheng (06/08/09 12:18 PM)
#17500 - 06/08/09 12:48 PM Re: Invalid path to data dictionary error (AR9.0A) [Re: David Cheng]
Hi, David,
I know you've indicated they are only using Ledger, Receivables and Lanpak. However, when you look at their datapath, do you see any data files other than those beginning with AR and GL (as well as the ADSPROF.xxx file)?
I'm wondering if, at some point, they did have/create some other data that is now causing the 1212 error.
#17513 - 06/08/09 04:48 PM Re: Invalid path to data dictionary error (AR9.0A) [Re: Softrak Support]
David Cheng Offline
New Guy
Here's the list of files that are inside the dict folder:
08/10/2006 11:02 AM 21,504 $L65AI.ssi
08/10/2006 11:02 AM 258,392 $L65AR.ssi
03/06/2009 05:01 PM 11,264 @@81AI.ssi
03/06/2009 05:01 PM 134,492 @@81AR.ssi
01/14/2003 01:24 PM 69,120 @B65AI.SSI
06/07/2005 05:08 PM 951,392 @B65AR.SSI
01/14/2003 01:26 PM 62,464 @I65AI.SSI
01/14/2003 01:26 PM 827,072 @I65AR.SSI
09/28/2004 04:19 PM 68,096 @I68BI.ssi
09/19/2005 02:00 PM 908,972 @I68BR.ssi
03/09/2009 04:57 PM 95,744 @I80AI.ssi
03/09/2009 04:57 PM 1,319,732 @I80AR.ssi
10/13/2006 01:29 PM 56,320 @J68BI.ssi
10/13/2006 01:29 PM 761,552 @J68BR.ssi
11/16/2004 11:14 AM 2,048 @K68ZI.ssi
11/16/2004 11:14 AM 20,672 @K68ZR.ssi
01/14/2003 01:30 PM 33,280 @L65AI.SSI
01/14/2003 01:30 PM 462,092 @L65AR.SSI
01/17/2003 12:18 PM 34,304 @L68BI.SSI
01/17/2003 12:18 PM 477,212 @L68BR.SSI
03/06/2009 05:01 PM 36,864 @L80AI.ssi
03/06/2009 05:01 PM 517,112 @L80AR.ssi
05/14/2009 12:35 PM 56,832 @L90AI.ssi
05/14/2009 12:35 PM 770,372 @L90AR.ssi
03/13/2003 05:20 PM 95,232 @N65AI.SSI
03/14/2003 12:28 PM 1,290,332 @N65AR.SSI
08/26/2004 12:04 PM 95,744 @N68BI.ssi
08/26/2004 12:04 PM 1,327,292 @N68BR.ssi
03/13/2003 02:22 PM 105,984 @O65AI.SSI
03/13/2003 02:22 PM 1,424,312 @O65AR.SSI
08/26/2004 12:44 PM 105,472 @O68BI.ssi
08/26/2004 12:44 PM 1,460,012 @O68BR.ssi
11/13/2003 03:19 PM 58,880 @R65AI.SSI
12/15/2003 11:04 AM 819,092 @R65AR.SSI
04/25/2008 03:50 PM 88,064 @R80AI.ssi
05/05/2008 02:12 PM 1,208,432 @R80AR.ssi
06/23/2008 11:55 AM 95,744 @R80BI.ssi
06/23/2008 11:55 AM 1,338,212 @R80BR.ssi
03/19/2009 04:42 PM 131,072 @R90AI.ssi
03/19/2009 04:42 PM 1,824,992 @R90AR.ssi
03/06/2009 05:01 PM 1,024 EZ61AI.SSI
03/06/2009 05:01 PM 5,972 EZ61AR.SSI
01/15/2003 02:18 PM 11,264 JC61AI.SSI
01/15/2003 02:18 PM 140,372 JC61AR.SSI
01/15/2003 02:30 PM 8,704 LW60CI.SSI
01/15/2003 02:30 PM 102,152 LW60CR.SSI
01/15/2003 03:56 PM 31,744 LW66AI.SSI
01/15/2003 03:56 PM 411,692 LW66AR.SSI
06/26/2003 02:39 PM 3,584 MC61AI.SSI
03/06/2009 05:01 PM 21,512 MC61AR.SSI
01/15/2003 04:09 PM 3,584 QH61DI.SSI
01/15/2003 04:09 PM 29,492 QH61DR.SSI
01/15/2003 04:12 PM 1,024 SA60AI.SSI
01/15/2003 04:12 PM 5,552 SA60AR.SSI
as for the folders in the softrak folder:
06/04/2009 11:00 AM <DIR> ALLWKST
03/06/2009 05:04 PM <DIR> ALWIN
12/23/2004 04:28 PM <DIR> ALWIN-2
06/05/2009 03:59 PM <DIR> CRWIN
11/22/2004 10:31 PM <DIR> DATA
07/20/2007 02:04 PM <DIR> DCWIN
06/08/2009 01:39 PM <DIR> DICT
03/07/2008 09:55 AM <DIR> FSDesigner
06/08/2009 08:36 AM <DIR> Ledger
06/08/2009 08:40 AM <DIR> Receivables
11/22/2004 10:31 PM <DIR> SPELL
06/08/2009 07:15 AM <DIR> system
07/20/2007 02:19 PM <DIR> unpack
07/20/2007 01:02 PM <DIR> Updates
I kept the older version of Ledger and Receivables after the update, the new version are installed inside the new folder (Ledger and Receivables). I don't see any other modules besides Ledger and Receivables
#17514 - 06/08/09 04:57 PM Re: Invalid path to data dictionary error (AR9.0A) [Re: David Cheng]
Hi, David,
I'll take a look at these. What I was referring to earlier were the data files which would be stored in their data folder.
Would you refer to my earlier message and check for the existence of files, other than ADSPROF, AR* and GL*? Thanks.
#17515 - 06/08/09 05:18 PM Re: Invalid path to data dictionary error (AR9.0A) [Re: Softrak Support]
Hi, David,
The date that keeps jumping out at me is 3/06/2009. This date doesn't match the date for the dictionaries its associated with. As well, I note that the ALWIN folder has a date of 3/06/2009.
Based on the dictionary files with this date and the folder date, I believe those dictionaries took on the date of an ALWIN (or GL8.1A) install that occurred on March 6th. As that date is later than the date that should be associated with the files, they are not being properly updated by subsequent installs.
#17525 - 06/09/09 02:10 PM Re: Invalid path to data dictionary error (AR9.0A) [Re: Softrak Support]
David Cheng Offline
New Guy
I removed the files that were dated at 03/06/2009, and reinstalled the ALWIN update that was applied on 3/06/2009, the DICT folder now listed as this:
09/27/2007 01:17 PM 11,264 @@81AI.ssi
09/27/2007 01:17 PM 134,492 @@81AR.ssi
05/08/2006 03:10 PM 36,864 @L80AI.ssi
03/21/2007 12:09 PM 517,112 @L80AR.ssi
06/09/2009 11:04 AM 0 dir.txt
11/17/2004 11:30 AM 1,024 EZ61AI.SSI
11/17/2004 11:30 AM 5,972 EZ61AR.SSI
06/09/2005 07:33 PM 21,512 MC61AR.SSI
It looks like the file dates have been corrected. But it still gives out the invalid path to data dictionary error.
*** Edited ***
I uninstalled Receivable 9.0A and reinstalled it, this time it was able to convert the database. It looks like the Ledge update was the cause of the problem.
Edited by David Cheng (06/09/09 02:24 PM)
1 registered (rah), 37 Guests and 3 Spiders online.
14668 Topics
