#16863 - 04/20/09 05:58 PM Re: Obtaining prior month balance in Bank Rec [Re: Retired_Guy]
Cool Aid Offline
Loc: Victoria, BC, Canada
Is it possible to get a total or listing of outstanding items for each reconciled period? If so, I could then recalculate the cash balance as I have the cleared amounts from the Gridview you provided me.
Thanks for the add'l info re: Gridview, I will browse through the forum when I have a chance.
Tanja
#16868 - 04/20/09 07:36 PM Re: Obtaining prior month balance in Bank Rec [Re: Cool Aid]
Hi Tanja,
Actually, you can see the bank balance "as at" any particular date by highlighting the bank in the Bank Inquiry function and changing the "Calc as of" date at the bottom of the form.
#16872 - 04/20/09 07:44 PM Re: Obtaining prior month balance in Bank Rec [Re: Retired_Guy]
Tanja:
It would be possible to use GridView work out the o/s items at any time but due to the fact that this information is not stored in BankRec it requires a complex filter to work it out.
Andrew's suggestion may be all you need.
#16891 - 04/21/09 04:54 PM Re: Obtaining prior month balance in Bank Rec [Re: Retired_Guy]
Cool Aid Offline
I tried to get the bank balance as at a date using the Calc As Of function but for prior periods, it still only gives me the balance as of the last reconciled date. We have reconciled to Jan09 and that is the balance that is returned for any dates entered prior to then. I can get current balances for the unreconciled periods, but for any reconciled periods all it returns is the last reconciled balance. Is this the intent of this function?
I appreciate all the assistance you have given me; unfortunately it seems I may have to re-reconcile the account manually and then adjust BR and GL to match.
#16892 - 04/21/09 06:14 PM Re: Obtaining prior month balance in Bank Rec [Re: Cool Aid]
Hi Tanja,
You're right - it only goes back to the last reconciled balance. Sorry, that's the way it was designed. We might be able to produce a View that calculates back from the current balance to get you what might have been the "cash balance" as at the statement date. I'll see what I can do.
3 registered (Samuel Kopstick, 2 invisible), 177 Guests and 1 Spider online.
14628 Topics
