#16202 - 03/03/09 12:17 PM Interest Aging - A/R
fishers Offline
Stranger
To make the question simpler:
When I create an interest batch in Adagio Receivables the interest batch which is created has a due date the same as the invoice date.
How do I make the interest batch have a due date the 25th of the following month?
-LA
#16203 - 03/03/09 12:52 PM Re: Interest Aging - A/R [Re: fishers]
Hello Fishers:
You could manually edit the Due Dates in the batch. That works OK for a small number of invoices, admittedly not so well for a larger number.
The concept is that the interest charges are due immediately, not at a later date. That's pretty standard. There's probably a good reason why your firm gives terms on interest due but could you explain it for us?
#16237 - 03/05/09 01:26 PM Re: Interest Aging - A/R [Re: Bruce Gardner]
fishers Offline
Stranger
You were correct in saying that interest charges are due immediately. I made a preliminary assumption based on initial discrepancies between the old AccPac statements and the new Adagio statements.
Thanks for your help. I did initially try to manually change the dates although it did not seem to keep the dates I changed them to.
-LA
