#16111 - 02/24/09 09:00 PM Re: Actual Cost [Re: SusanTennier]
Hello Susan:
Actually you can reduce the Actual Cost without reducing the Quantity.
Look at the ICIADJ.xls file in the \Softrak\ICWIN\SAMDATA folder. To reduce just the cost, you would enter 0 for the "Stock Qty" column and a negative figure for the "Ext Cost" column. This results in a transaction where "Type" = "Cost decrease".
As suggested earlier, I would test this in Sample data first.
#16112 - 02/24/09 09:09 PM Re: Actual Cost [Re: Bruce Gardner]
Great to hear this! Thanks. I will try it.
#16113 - 02/24/09 10:31 PM Re: Actual Cost [Re: SusanTennier]
It worked like a charm. It was weird that it forced me to provide a location when there were no quantities involved, but it had no bearing on the end result. This import saved me from entering over 200 adjustments manually. Thanks again!
4 registered (Salman, Softrak Support, Lauren Stief, 1 invisible), 69 Guests and 2 Spiders online.
14567 Topics
