#16014 - 02/17/09 07:13 AM NEGATIVE QTYS IN OE AND PO
CARTERS Offline
Stranger
Loc: NOVA SCOTIA,CANADA
WE HAVE NEGATIVE AMOUNTS IN OUR ORDER ENTRY IN THE SALES ORDER COLUMN.WHEN ENTERING AN ORDER ON A PARTICULAR # IT WILL SHOW AS A NEGATIVE QTY ON A SALES ORDER ALREADY. WE ALSO HAVE NEGATIVE AMOUNTS ON PO'S SHOWING AS ON ORDER. HOW DO WE DELETE THESE.
#16016 - 02/17/09 01:04 PM Re: NEGATIVE QTYS IN OE AND PO [Re: CARTERS]
Is the option to "allow inventory levels to be below zero" turned on in the Inventory company profile?
BTW - Writing in ALL CAPITALS is seen as "shouting" in the forum/e-mail world.
#16017 - 02/17/09 01:49 PM Re: NEGATIVE QTYS IN OE AND PO [Re: CARTERS]
Hello:
Some of your "On Sales Order" and "On P/O" quantities are negative. How many? How about your On Hand quantities? Are they correct?
To correct the "On Sales Order" quantities:
-Backup the Inventory Control (IC) and OE datasets using the Backup function on the File menu
-Run Data Integrity Check in IC
-If there are errors reported, cut & paste the contents of the dialogue box into Word or Notepad
-Click on the "Rebuild" button (if not greyed out)
-If that process is successful, go to the OE module
-Do the same process there.
-Let us know the results.
Do you use POA for your P/O's? If so, there is seaprate process to correct "On P/O" quantities but first let us know how you make out with this step.
#16018 - 02/17/09 02:44 PM Re: NEGATIVE QTYS IN OE AND PO [Re: Bruce Gardner]
You may have to Run Data Integrity Check and Rebuild more than once, until you get a clean result.
0 registered (), 342 Guests and 2 Spiders online.
14666 Topics
