#15810 - 01/29/09 12:53 PM Reporter Help
Kevin Jenkins Offline
Adagio Graduate
Loc: Charlottetown, PE
Help! My GL 9.0 help files work fine, but I can't load help for Financial Reporter. I get the following:
[b][b]Internet Explorer was unable to link to the Web page you requested. The page might be temporarily unavailable.
Please try the following:
Click the Refresh button, or try again later.
If you have visited this page previously and you want to view what has been stored on your computer, click File, and then click Work Offline.
For information about offline browsing with Internet Explorer, click the Help menu, and then click Contents and Index.
As I say, GL help works fine, but FinRep help has the same error message for all catagories. Any ideas?
#15814 - 01/29/09 02:45 PM Re: Reporter Help [Re: Kevin Jenkins]
Hi Kevin,
The name of the Financial Reporter help file for the Ledger version 90A is LedgerFinRep.CHM. Can you find this file on your local C drive? It needs to be there due to a Microsoft security patch that prevents loading CHM help files from a network drive.
Adagio uses a 'help file path' within your Windows Registry, so that when you choose to access the Help file, Adagio knows where to look on your local drive. Perhaps the main Ledger.chm help file is there, but the Financial Reporter help file is not.
Typically, you would find the help files in C:\softrak\ledger.
#15815 - 01/29/09 02:59 PM Re: Reporter Help [Re: Softrak Support]
Adagio Graduate
Both files appear to be there in c:\softrak\ledger ..... how do I tell Adagio to search there for them?
#15819 - 01/29/09 04:53 PM Re: Reporter Help [Re: Kevin Jenkins]
Hi Kevin,
As mentioned in the earlier post, it's stored in the Windows Registry. To see where this workstation loads Ledger help from, go to:
HKEY_Local_Machine / Software / Softrak Systems / Adagio Ledger
key: HelpDirectory
If the key is the path you indicated, then something else is a problem that we are not aware of. You may want to try re-running the workstation setup for Ledger.
Do other workstations that have access to Adagio Ledger exhibit the same problem?
#15828 - 01/30/09 07:04 AM Re: Reporter Help [Re: Softrak Support]
Adagio Graduate
I ran the workstation setup and my Fin Rep help is back! Thank you for the excellent support!!!!!!!!
0 registered (), 104 Guests and 0 Spiders online.
1869 Members
14602 Topics
