#15647 - 01/14/09 12:40 PM Physical Inventory & Adjusted Unit Cost
*Confused* Please help.
When using the Transactions/Physical Inventory/Enter-Edit Physical Inventory and the quantity is changed, the adjusted unit cost automatically changes as well.
If we export our physical inventory worksheet and change the quantity, are we suppose to manually enter an Adjusted Unit Cost?
I don't understand why the unit cost would change at all because if an item is lost, the cost for that item should also be lost, leaving the average unit cost on the remaining quantites consistent.
We have 4 stocking locations and we're thinking of exporting the worksheets, entering the new quanties, then importing. Using this method, my question is, how do I post new quantities at each branch location and keep the average unit cost correct in the end? Do we have to enter anything in the adjusted unit cost column at all? Or will Adagio add the cost of each added quantity and subtract the cost of each lost quantity automatically? Therefore keeping the average unit cost of the remaining inventory consistent. Unless there are no quanities left at any location on an item in which case the average unit cost should go to zero.
Also, can the lots be merged to one before we start so we can work with one average unit cost instead of trying to deal with inconsistencies from lot to lot on top of everything else?
#15654 - 01/14/09 03:24 PM Re: Physical Inventory & Adjusted Unit Cost [Re: SusanTennier]
If you do not export/import the Unit Cost field with a Physical Inventory, this value will be defaulted from the item master. It calculates the appropriate unit cost to do exactly as you describe (losing the cost with the item), and deals with the scenario if there are multiple costing lots with different average values, just like if you shipped the same qty as is being lost.
You should not have to change the Unit Cost value unless you want to add/subtract a different amount than as described above.
You should be aware that costs are not stored by location in Adagio Inventory, so if you use FIFO/LIFO costing and have multiple costing lots, they do not necessarily relate to particular loations. So if you create 4 physical inventory worksheets, the costs are determined only if there is a different in the physical count and at the time they are imported.
If you post a stock count loss, it will be costed as if the qty was shipped. There is no place to identify a specific costing lot, should more than one be in use. If you want to remove qty and cost from a specific costing lot, you should use the Adjustments function and not Physical Inventory.
Also, when a Physical Inventory is imported, the quantities and costs are not yet updated - you still have to post it. This means that if the results of the import are not what you expected, nothing bad has happened yet to your data. You can print the phys inventory report, make changes, or re-import a corrected file if required. Definitely make a backup before Posting!
#15703 - 01/19/09 12:51 PM Re: Physical Inventory & Adjusted Unit Cost [Re: Softrak Support]
This is great information. Thank-you.
0 registered (), 346 Guests and 4 Spiders online.
14627 Topics
