#15698 - 01/16/09 07:50 PM Need help here re Inventory (receipts)
Fong Offline
Adagio Ace
We have deleted some inventory items long time ago so every time we run the DIC it reports over 900 errors like below examples:
Adagio Inventory: Application Integrity
Receipt M25 has non-existing item ZZ3215.
Receipt M22 has non-existing item ZZ3213
All these receipts are still showing active in the Edit Receipts window. Is it safe to delete them there?
Thanks.
#15699 - 01/16/09 08:26 PM Re: Need help here re Inventory (receipts) [Re: Fong]
Hi Fong,
Indeed if an item has been deleted and it still exists on an active Receipt, this will cause an integrity error. To make the error go away, you have to either remove the receipt detail or add the item number back. And of course, adding back the item is likely not the desired solution.
As long as the Receipt is complete, then you can remove the receipt. Day End Processing in Inventory will offer to delete all completed receipts that are older than (30) days. If a Receipt is still 'Active' rather than 'Complete' and has a non-blank invoice number, then Day End will mark the receipt as Complete, and in (30) days it can be deleted.
Of course, it is also safe to delete a receipt if you know it is OK to do so. The only danger is if you delete an Active Receipt that has not been transferred to Payables. Receipts need an invoice number in order for Day End to send the receipt to Payables as an Invoice.
Make a backup copy of your data before doing any of this, in case you delete something that you actually still need.
#16074 - 02/20/09 06:05 PM Re: Need help here re Inventory (receipts) [Re: Softrak Support]
Fong Offline
Adagio Ace
How to delete or complete an active receipt that was posted in ACCPAC Inventory Control years ago?
#16077 - 02/20/09 06:28 PM Re: Need help here re Inventory (receipts) [Re: Fong]
Fong Offline
Adagio Ace
Can't remove the receipt detail. It's not allowed. I put back the deleted item and yes it let me completed the order. But now I have a negative quantity showing in IC as Qty on PO. Any more suggestion? I did a DIC but problem not solved.
#16078 - 02/20/09 06:45 PM Re: Need help here re Inventory (receipts) [Re: Fong]
Fong Offline
Adagio Ace
I AM HAPPY TO ANNOUNCE that I did a DIC in POA and let it fixed all and then went back to IC and deleted the items I'd put back. It WORKED!!!
