#15487 - 12/20/08 04:28 PM Repeat column headings in the Financial Statements
CarlosC Offline
Adagio Fan
Loc: North Bay, ON, Canada
How the heck do you repeat the column headings on the financial statements from page 2 and beyond?
Curr. Curr. Last
Month YTD Perc LYTD
Thank you,
Carlos.
#15488 - 12/20/08 11:40 PM Re: Repeat column headings in the Financial Statements [Re: CarlosC]
Hello Carlos:
You want to "Freeze" the title rows. Do the following:
-Decide which rows you want to repeat (i.e. the first 8 rows)
-Highlight those 8 rows (click on the grey row numbers on the left)
-Select Format then Rows then Freeze
Those 8 rows will now repeat on every page of your statements.
#15489 - 12/21/08 08:27 PM Re: Repeat column headings in the Financial Statements [Re: CarlosC]
Hello Carlos:
I've re-read your question and realized my answer may not be correct. My answer works if you want to repeat all of the titles on the report, including the column headings.
However, if you want only the column headings, that technique won't work. Could you clarify what you need?
#15493 - 12/22/08 09:48 AM Re: Repeat column headings in the Financial Statements [Re: Bruce Gardner]
CarlosC Offline
Adagio Fan
Hi Bruce,
I did want to re-print only the two lines of column headings but I am okay with printing the all of the lines on top until they come up with a better way of repeating only certain rows.
Thank you for replying.
Cheers,
Carlos.
#15497 - 12/22/08 11:26 AM Re: Repeat column headings in the Financial Statements [Re: CarlosC]
Hi Carlos,
There is no option in the Financial Reporter to repeat particular rows at the top of each page, that are the Top N rows (as Bruce initially responded with). So if these column headers are rows 8 and 9 (for exanple), you cannot set only rows 8 and 9 to repeat on each page. It has to be rows 1 to 9.
#15499 - 12/22/08 11:31 AM Re: Repeat column headings in the Financial Statements [Re: Softrak Support]
Michael Mulrooney Offline
If your statement is a "fixed" size then you can put a manual page break ( CTRL-B ) and then repeat the two lines you want at the top of your page.
1 registered (Annemarie Nordman), 172 Guests and 0 Spiders online.
1865 Members
14512 Topics
27 28 29 30 31
