#15082 - 11/12/08 01:21 PM missing "statement group" in financial reporter
Good Morning,
My rep is on vacation, so I am writing to you. I am running 9.0a Adagio Ledger, 2008.04.02.
In the GL Financial Reporting Suite, I am trying to add a statement group to one of my companies. (I have multiple companies) In two of the companies I have it set up, but in two more the "statement Group" does not appear when you are in Maintain Financial Groups. (Yes I have under view statement groups checked.)
Also when I open Maintain Financial Reports (only on two of the companies) the first blank spread sheet comes up with this message "an attempt was made to access an unnamed file past its end."
I do not know if these two items are related, but I was wondering if any one else has had this problem.
Please let me know how to fix this problem.
Sincerely,
Darleen Cavanaugh, Controller
Baltimore Car & Truck Rental, Inc.
#15084 - 11/12/08 03:21 PM Re: missing "statement group" in financial reporter [Re: ]
Hi Darleen,
This error isn't something I've heard of before. It sounds indicative of a corrupted file - that an index doesn't reference all the required details - or perhaps a financial statement that was initially set up in a statement group is no longer in the referenced location.
Are you able to open the Financial Reporter as the SYS user and edit Statement Groups without the error? If so, you may be able to re-edit the existing statement groups and re-select the report files, to re-connect.
If you get the error immediately upon opening the Financial Reporter, then this likely is a problem with the statement group file. Try getting everyone out of Adagio and in the data directory, rename the file GLRPTGRP.dat. It will be recreated the next time you log into Ledger as SYS and open the Financial Reporter. Of course, the statement groups would need to be re-defined.
