#14484 - 09/19/08 04:36 PM Open Payables Report doesn't match my G/L
Ali Offline
New Guy
Loc: British Columbia, Canada
any ideas why?
#14485 - 09/19/08 04:47 PM Re: Open Payables Report doesn't match my G/L [Re: Ali]
You've posted adjusting journal entries to that account in Ledger?
You coded an adjustment in Payables to the control account?
You changed the fiscal period of a transaction retrieved from Payables before posting it?
#14486 - 09/20/08 02:01 PM Re: Open Payables Report doesn't match my G/L [Re: Retired_Guy]
Hi Ali
There are so many other possible reasons besides the three Andrew mentions.
To troubleshoot, you want to start by retrieving and posting everything into the GL.
Then run the report as of today, and note the difference. If it's zero, then you are done - your problem is a timing problem which self-corrected.
Otherwise, continue running the report as of preceding month-ends, and note whether the difference is constant. If the difference is changing, then something happened in that month.
If you can nail down the month, then look at the GL transactions in the AP account in that month to see if anything doesn't have a source code starting with "AP". In general, the AP account transactions should ALL come from the AP module.
There is no guarantee this will work, but it's the first and easiest place to start. Let us know what happens.
1 registered (Softrak Support), 147 Guests and 0 Spiders online.
14588 Topics
February
