#13810 - 07/29/08 06:07 PM
Re: Error Message
[Re: Chretien9710]
Softrak,
I tried using the zip method with the correct files, however now when I try to open Ledger it is saying my report tables drive is set to G: and that the drive does not contain current report tables.
Any ideas??
Darcy Chretien
#13811 - 07/29/08 06:13 PM
Re: Error Message
[Re: Chretien9710]
Did you delete G:\QRASP ? That's the report tables drive (and directory). All workstations should have a mapping for drive "G:" that is the same.
#13812 - 07/29/08 06:18 PM
Re: Error Message
[Re: Retired_Guy]
Andrew,
No I didn't delete it, all I did was copy over the old QRAL9* files. Nothing was deleted though.
Darcy Chretien
#13815 - 07/29/08 06:46 PM
Re: Error Message
[Re: Softrak Support]
Softrak,
Indeed there is a \QRASP file on this workstation. In regards to the folders i didn't have any of the options set up like that.
What should happen in regards to the install, from an alternate workstation without that file??
Darcy Chretien
#13816 - 07/29/08 07:06 PM
Re: Error Message
[Re: Chretien9710]
Softrak,
The hang up is that on each workstation it is saying the Report tables are set to G:, but it doesn't contain current report tables for Ledger so it won't install from any workstation.
Darcy Chretien
#13819 - 07/29/08 08:30 PM
Re: Error Message
Softrak,
Thanks again for your help. Ledger is reinstalled, however even though the QRTAL9* files were renamed before the reinstallation the Detail listing will still not print as the files again installed with the old dates.
Darcy Chretien
0 registered (),
552
Guests and
2
Spiders online. |
14630 Topics
