#13583 - 07/16/08 09:59 AM Gridview - What table?
I'm trying to create a Gridview that will show us what to order.
I created a Gridview using I/C Items (1,3) Master that shows Item#, Description, QTY on Hand, QTY on PO, QTY on SO and Optional Amount Field 1 (Minimum QTY). I then used a filter so it will only show items that the QTY on Hand + QTY on PO is < QTY on SO OR QTY on Hand + QTY on PO is < Minimum QTY. The problem is that the QTY on Hand is all warehouses and Item Location is not available in this table so I can't tell it show only Location = WA.
I created another Gridview using Table *IC Item Loc w IC Item. This table however doesn't have a field available for Optional Amount Field 1.
Neither table has a field for Reorder Data Min Level.
We don't really need the elaborate Min Max Reorder QTY and Projection in IC which is why I thought using Optional Amount Field 1 would be better. Our staff can easily enter minimums here from within Item Maintenance. The problem is how to get the results we need while showing quanties ONLY at 1 location.
I should also mention that I tried using IC Reorder report which works well except again it shows QTY on Hand total of all locations.
Please advise.
Edited by SusanTennier (07/16/08 10:26 AM)
#13584 - 07/16/08 10:57 AM Re: Gridview - What table? [Re: SusanTennier]
Hi Susan
You are stretching GridView beyond it's comfort zone. You may be able to do what you want using various views linked together into a workspace, but you won't be able to print that onto paper, which is what you probably want. In any case, there is no table, not even a composite table, in GridView that will allow you to put everything you want onto one report.
On the other hand, this is the kind of report that Crystal Reports for Adagio is designed for. If you have that tool and know how to use it, I would recommend trying to create the report there. This is one of the more complicated reports to create though, so give yourself some time to get up the learning curve.
#13586 - 07/16/08 12:22 PM Re: Gridview - What table? [Re: Steve Schwartz]
I was afraid that someone would say I need another program. Maybe I should have purchased Chrystal Reports for Adagio instead of Gridview? I currently use only one Gridview successfully and was hoping to develop some other useful views but running into the problem with fields not being available in the tables that I need each time. Maybe I'll have to try to come up with something with linked views or try the evaluation of Chrystal Reports.
#13587 - 07/16/08 12:35 PM Re: Gridview - What table? [Re: SusanTennier]
Is there a list anywhere that shows all the fields of all the tables?
#13594 - 07/16/08 03:44 PM Re: Gridview - What table? [Re: SusanTennier]
Hi, Susan,
Have you looked at any of the 'composite' tables? When you first select 'new' you may have to scroll down further in the list of available tables but may well find what you are looking for in one of the Composite 'C' tables.
There is also a tool that will print the tables and fields contained within them for you that is available from our website for download. Go to the Support | TechTips area and the last item in the Adagio Operations section is for Adagio Data Dictionary Exporter. From there, you will find a link to the software and another link to the documentation (which I recommend you download and read if you plan to use the tool).
The DDE creates an Excel workbook in the datapath used when you log in.
#13596 - 07/16/08 04:24 PM Re: Gridview - What table? [Re: Softrak Support]
I find Gridview is great for people who want to get simple information from the accounting system. They know the data is in the acounting system and just want to find it and see it. A lot of it will be one time things, but you can set up commn Views to be used over and over again. They my want a list of items that are out of stock, list of clients owing money with phone numbers, list of orders that were shipped last month to clients in BC. Most staff members should be able to create these reports.
Crystal Reports is designed for the more computer wise client. With it, you would normally be creating monthly rports, with totals and subtotals, pulling data from many different data files.
0 registered (), 335 Guests and 3 Spiders online.
14673 Topics
