#13275 - 06/23/08 11:29 AM Reports after reloading app
doswalt Offline
Loc: AL
I have re-installed applications from workstation to the server and now some gridviews and crystal reports are not printing data.
Gridview error -"The Data, for the table "@N80AADJ", with the extension 'XXX', was not found in the directory 'H:".
How is the best way for me to correct this?
David
#13277 - 06/23/08 11:35 AM Re: Reports after reloading app [Re: doswalt]
Hi David,
This dictionary is for the Adjustment audit list. Was it printed and purged, or deleted? If the data file ICADJTR.dat doesn't exist, this is when GridView gives this error.
You may also want to ensure that you have the correct dictionaries installed in the \softrak\dict directory. If there is a mismatch between the dictionary and the data, naturally there could be problems.
#13281 - 06/23/08 11:51 AM Re: Reports after reloading app [Re: Softrak Support]
doswalt Offline
Loc: AL
How is the best way to ensure correct dictionaries installed?
David
#13283 - 06/23/08 12:02 PM Re: Reports after reloading app [Re: doswalt]
Hi, David,
If current IC8.1A(070825) is being used, current IC tables are:
@N80AR.ssi 5/28/2007
@N80AI.ssi 5/04/2007
You can verify the dates of these files in the Softrak\Dict folder.
#13284 - 06/23/08 12:44 PM Re: Reports after reloading app [Re: Softrak Support]
doswalt Offline
Loc: AL
Now I see my issue. My report was building on an Adjustments table from an earlier version of Inventory.
David
#13289 - 06/23/08 01:52 PM Re: Reports after reloading app [Re: doswalt]
doswalt Offline
Loc: AL
Is there a way to add back the dictionares for the prior versions to enable old reports to run?
David
#13290 - 06/23/08 01:59 PM Re: Reports after reloading app [Re: doswalt]
Hi, David,
What version of IC are you referring to? In IC8.0B the tables changed and they changed again in IC8.1A.
You'll need to rewrite your view to accommodate the changes.
#13291 - 06/23/08 02:12 PM Re: Reports after reloading app [Re: Softrak Support]
doswalt Offline
Loc: AL
Updating the views are no trouble at all....re-writing the crystal reports goes much slower for me.
David
4 registered (Salman, Softrak Support, Lauren Stief, 1 invisible), 69 Guests and 2 Spiders online.
14567 Topics
