#13109 - 06/12/08 10:57 AM Sort Order-Pre-check Register/Check Register
doswalt Offline
Loc: AL
Accounts Payable 8.1a (070919) - What would cause the sort order of the Pre-Check Register and Check Register to be different? I had thought the order would always be the same.
Thanks, David
#13113 - 06/12/08 11:50 AM Re: Sort Order-Pre-check Register/Check Register [Re: doswalt]
What's different?
#13114 - 06/12/08 11:54 AM Re: Sort Order-Pre-check Register/Check Register [Re: doswalt]
Hi, David,
The precheck register will print all vendor's and balances that appear when the Print Checks/Advices are generated. This is based on the criteria you enter on the Register screen.
The check register prints those items for which a check was really created.
However, the sort order is the same on both reports.
#13115 - 06/12/08 12:13 PM Re: Sort Order-Pre-check Register/Check Register [Re: Softrak Support]
doswalt Offline
Loc: AL
I assumed the sort order would be the same, but a client has sent me PDF files that have a different sort (only a few are in a different order)that appears to show a different sort order due to capitalization in the vendor code.
David
1 registered (Samuel Kopstick), 150 Guests and 0 Spiders online.
14616 Topics
