#1285 - 08/03/01 12:59 PM Re: Quik Reports for Windows
Hello Deborah
So I am assuming then that my reply to Nicole about the conflict in Crystal versions is not likely the problem because they do not use ACCPAC for Windows - only Plus? Could it be possible that they use another software application that uses Crystal files? Perhaps ContactMaster for Windows (which integrates with ACCPAC AR DOS, or possibly Maximizer)?
If you are quite sure that no other product is using crystal, then I need some specific questions answered:
1. When exactly (while working in QRWIN) does this error occur? Just saying while working in the program does not tell me much. Is it while creating a new report - editing an existing report - does the error occur right after clicking on a specific button or option? Does it happen when accepting a value or inserting a field?
2. What version of ACCPAC Plus are they using?
3. What version and release date of QRWIN are they using?
4. Where was QRWIN installed - on a Server or on a PC's local hard drive?
5. If on a Server, was a workstation setup done on the system experiencing the problem, or does more than one system get this problem?
6. Is the report a compiled report or do they actually go into QRWIN Designer and open the report?
GPF's can occur for many reasons. It could be due to version incompatibility or maybe QRWIN just needs to be reinstalled, and a new workstation setup be done on this PC.
You could try this first, being the fastest thing to do.
On the PC having the problems:
1. Rename the QRW program directory. If you are sure that no other application uses Crystal, then also rename this system's local "Crystal" directory. It can be found under the Windows or Winnt directory (eg C:\Windows\Crystal).
2. Reinstall QRWIN.
Hope this helps,
Softrak Support
#1287 - 08/07/01 01:30 PM Re: Quik Reports for Windows
Thanks for the information, Debbie.
So when closing a report from the Quik Reports for Windows designer on a Win2000 machine, you are getting a GPF error. There must be something running in the background that is causing this error, as we cannot duplicate this error on our Win2000 machine that that version of QRWin.
So I guess the next 'list' of questions:
- Does this happen for all of your saved reports, or only specific reports? IF only certain reports, could there be a pattern, such as reports based on a certain data set or program?
- Can you create a new report on this station, save it, and close it without getting the error?
- After getting the error, do you reboot the station? There likely are some program files that are not shut down internally after a crash, and rebooting will refresh these.
- Do you have any special settings for the Win2000 login? Full supervisory rights?
- Do you utilize different Currency settings in Windows Regional Settings? I would imagine that you would be. If this is related to the problem, that would mean that you should never have been able to close the program without an error. Should it have been working OK in the past, this would not be an issue.
- Make sure as little as possible is running at the same time while you evaluate this, including virus checking, Accpac Plus (if possible, for now), Word or Excel or other large programs, etc. If another program is running that is causing this GPF, then of course they would have to be run independantly. Should you be able to narrow this down, then you can start running any of the other programs you had to shut down.
- You may have to re-install Quik Reports for Windows. Either run an 'uninstall' procedure or rename the \QRW directory, then re-install.
Softrak Support
