#1253 - 07/26/01 09:07 AM Quik Link 6.1a(971103)
Is the above product compatiable with Windows Millennium and MS Exp.
#1254 - 07/26/01 11:53 AM Re: Quik Link 6.1a(971103)
Hi Nicole,
Though there has not been extensive testing running Quik Link 6.2A (971103) under Windows ME or Office XP, I do not anticipate any major problems. Quik Link works well under Win 98 and Office 2000, so unless there were major structural changes in XP, this should not affect Quik Link. You may need the newest Quik Link 6.5A with Office XP.
Of course, this does not mean that we're guaranteeing no problems under Win ME or XP. There are differences in how Windows ME is set up compared to others (ie the Config.sys file and where to put the 'Files = 250' statement), so Windows must be configured correctly.
Softrak Support
#1255 - 07/27/01 03:36 AM Re: Quik Link 6.1a(971103)
I need to know if the 6.1a (971103) Quik Link is Windows Millennium an MS Exp compatiable.
#1256 - 07/28/01 02:14 AM Re: Quik Link 6.1a(971103)
Dear Nicole
In QL Version 6.1A there were only the following releases:
QL V6.1A 960619
QL V6.1A 960917
In QL version 6.2A there were:
970530
970721
971103
We are now up to QL V6.5A (000415), with a new release expected sometime in the near future.
So, our last response is what you should look at as the answer to your original question.
Regards
#1258 - 08/07/01 11:33 AM Re: Quik Link 6.1a(971103)
Hi Nicole/Deborah,
Version 6.5A is the most current release; if you were told otherwise, this is in error.
Quik Link 6.1A (1996 release dates) is not compatible with Office 97 or later versions of Excel, so this will not be useful if you have more recent versions of Excel.
When you use Quik Link (6.2A or later) on a data set where security is turned on in WSM, you must enter the High level password on the link, otherwise you will get the Error 2202 you indicated above. If the link does not have the correct password entered on it, you will have to recreate the link (with the same name, overwriting the existing link, and from the Password button, enter the High level password, and save the link and your workbook.
Also note that WSM 7.0 changed the way it handles security, and Quik Link (any version) cannot read data with this type of security enabled. I believe you have to make a backup copy of data that you would use Quik Link to report on (rather than the secured live data) in this instance.
Softrak Support
#1260 - 08/28/01 12:40 PM Re: Quik Link 6.1a(971103)
Dear Deborah
Ok - I can sense your frustration level building!
Here are some things you can do to narrow down or eliminate what the actual problem could be:
1. Using Explorer, go to the directory where they keep their QL files. There should be two files for every worksheet they have - an .xls file and a .dnk file. (Ensure you are looking at 'all files'. If there is only the .xls files, then possibly the corresponding .dnk files did not get copied over to their local drive as they should have. Both types of files must exist in the same directory in order for QL to use them effectively.
2. When they open and save their QL worksheets, they must use the QL options to do so, not the Excel File Open & Save commands.
3. Ideally, Excel should exist on the same drive where you want to install QL, and it should be there prior to installing QL.
4. Can you create a brand new worksheet by going through the steps in QL? (Assuming you are working with an already initialized dataset) For example, (I will use GL):
a) Open QL and, from the main Excel Toolbar 'QuikLink' menu option, select 'Link' and define a new link (leave all default values in the Link Definition window as they are - just give the link a name such as 'gldata' if using the GLDATA@@.SAM dictionary.) then click Accept.
b) Now, select the 'Read' option from the QuikLink menu
c) Select 'Read Formulas or Values' and click OK
d) Select the newly created 'gldata' link and click OK
e) Now, let's select the ACCT, DEPT, DESC & BAL from the list of fields at the left, then click OK
f) Now you should be at the 'Quik Link - Read Values or Formulas' dialogue. Make sure that on the right-hand side, the option for 'Formulas' is selected, as this is what will determine a worksheet that can be updated in the way that you want. Click GO.
g) You should now see all the GL accts/depts and their balances on the worksheet.
h) Using the QuikLink toolbar menu option, now select File Save, and save the QL file. Note that two files will actually be created during the QL save process, the expected .xls file and a corresponding .dnk file. BOTH of these files must exist in the directory where they keep their QL workbooks.
i) To test the success of the save, exit out of this worksheet and Excel/QL now, and after going back into QL, select File Open from the QL menu option, and open the newly created QL workbook.
If you have no trouble creating and using a new worksheet, but still have problems when using a previously created QL file, then you may want to take a look at the QL manual, Chapter 1, page 1-12 for Redefining the Excel Links (it won't hurt) and also you may want to try just redefining the actual QL Links being used in the problem worksheets.
Hope this helps.
Softrak Support
#1262 - 08/29/01 11:14 AM Re: Quik Link 6.1a(971103)
That's awesome, Deborah!
Thank you for the kinds words of appreciation as well!
Sincerely
1 registered (StellaCPA), 180 Guests and 1 Spider online.
1865 Members
14510 Topics
27 28 29 30 31
