#12523 - 05/02/08 11:48 AM Inventory Control - G/L Listing
I am trying to do month end. I went through the order entry module and e/thing was fine. Then went to go through Inventory Control; printed the Receipt Audit List, the Adjustment Report, Shipment Audit List and Shipment Serial Number report; and then went to print the G/L listing and there is nothing there? HELP!
#12524 - 05/02/08 12:26 PM Re: Inventory Control - G/L Listing [Re: ]
Did you post anything in IC, since the last time you've retrieved the subledger into GL? If not, then this report will be blank. Has the batch already been retrieved into Ledger?
Look for the data file ICALBTCH (if you are using Adagio Ledger 90A) or the file ICGLBTCH (if you are using Ledger 1A or earlier). If this file is 0 bytes in size, it is empty. If it is greater than zero bytes, then there is information in the file, and the problem is with the report - and we are now aware of any problems with printing this report.
#12526 - 05/02/08 12:32 PM Re: Inventory Control - G/L Listing [Re: Softrak Support]
Not to sound completely dumb (although I am feeling that way), where do I look for the ICALBTCH?
#12539 - 05/02/08 04:50 PM Re: Inventory Control - G/L Listing [Re: ]
Not a dumb question at all! As this is a data file, you would need to look in your data directory. If you are not sure where that is, when you have Adagio IC open, move your mouse over top of your company name at the bottom of the window. You should see the data directory path appear at the bottom left of the window.
