#12483 - 04/30/08 10:48 AM Adagio Icons
Chretien9710 Offline
Hello All,
I have a client with two machines using Adagio on a peer to peer setup. In the morning the computer who "acts" as the server shows only the outline for the Adagio icons. It is only for the Adagio icons. I believe this to be a Windows issue, but have not had any success searching for anything. Any advice would be greatly appreciated!!
DC
Edited by Chretien9710 (04/30/08 12:02 PM)
#12494 - 04/30/08 02:35 PM Re: Adagio Icons [Re: Chretien9710]
This isn't something I have run across before. Do you mean the shortcuts for starting Adagio, or something else? What version of Windows is this?
What if you re-created a shortcut to an Adagio program - does this have the same scenario?
If you right-click on the shortcut and choose Properties, there should be a 'Change Icon' button, that loads the Adagio icon picture - does this work for you? This is built into the program, so it wouldn't be a matter of a missing file.
#12499 - 04/30/08 04:41 PM Re: Adagio Icons [Re: Softrak Support]
I did try the "Properties", "Change Icon" function, however it did not work, although I do see the picture for the program but it does not change. Recreating a shortcut seems to produce the same result after the machine is shut down and rebooted again.
DC
#12500 - 04/30/08 04:52 PM Re: Adagio Icons [Re: Chretien9710]
Have you checked the colour depth of the display? Perhaps someone changed it to 256 colours?
Presumably the icons are stilllaunching the Adagio modules properly.
#12504 - 04/30/08 06:23 PM Re: Adagio Icons [Re: Retired_Guy]
Andrew,
Yes the Adagio modules are all running fine, I will try your suggestion!
DC
1 registered (Howard S.-MMA), 80 Guests and 2 Spiders online.
14624 Topics
