#12186 - 04/09/08 04:25 PM date format
how do i change the date format from dd/mm/yy to mm/dd/yr in all adagio a/p, a/r, g/l? i recently updated my windows to windows xp professional and it changed the date formats that i was used to. Thanxs
#12187 - 04/09/08 04:33 PM Re: date format [Re: ]
Hi thuff,
Date formats for reports or for data entry? If for reports, then you can make this change in Adagio under the Reports menu and Report Options.
If for data entry, this change would be done in Windows Regional Settings (not in Adagio). The Short Date format is what you are looking at.
#12188 - 04/09/08 04:37 PM Re: date format [Re: ]
Lars Offline
Loc: Vernon, B. C.
Hi thuff - In your Control Panel, select the Regional and Language Options. From there, select the Customize button > Date and select the format you are used to. The only format that you can change within Adagio is the date format on reports which can be changed under File > Report Options.
Lars Glimhagen
Lars Glimhagen
Adagio Certified Trainer
Email: lars@lng.bc.ca
#12197 - 04/09/08 06:36 PM Re: date format [Re: Softrak Support]
IT'S FOR DATA ENTRY
#12199 - 04/09/08 06:39 PM Re: date format [Re: ]
Lars Offline
Loc: Vernon, B. C.
Hi thuff: Then you need to make the change in the Regional and Language Options under the Control Panel.
Lars Glimhagen
Lars Glimhagen
