#12162 - 04/09/08 01:34 PM Vista hangups
Lizzy Offline
New Guy
Loc: Calgary, AB, Canada
When most current versions of Adagio (including Lanpak 9) are installed on Vista Business SP1 server (peer-to-peer), attempts to open modules from any other workstation result in the second workstation “hanging”. There is no error message, just indefinite hang until the other workstation modules are closed.
User access control was turned off for installation, and is turned on for user access
Firewalls have been disabled
All windows users are administrators
Checksys shows no errors on either server or workstations
#12164 - 04/09/08 01:41 PM Re: Vista hangups [Re: Lizzy]
Hi Lizzy,
Can the second workstation log in if the first workstation exits?
#12165 - 04/09/08 01:41 PM Re: Vista hangups [Re: Retired_Guy]
Lizzy Offline
New Guy
Yes.
#12166 - 04/09/08 01:42 PM Re: Vista hangups [Re: Lizzy]
Does the Task Manager show either task as doing anything? (esp reading and/or writing any bytes?)
#12168 - 04/09/08 01:46 PM Re: Vista hangups [Re: Retired_Guy]
Lizzy Offline
New Guy
Task Manager on second workstation shows "Not Responding", first shows "Running"
#12173 - 04/09/08 02:28 PM Re: Vista hangups [Re: Lizzy]
Lizzy Offline
New Guy
Andrew, where are you?
#12174 - 04/09/08 02:42 PM Re: Vista hangups [Re: Lizzy]
Actually, I'm referring to under the Processes tab, not the Applications tab. The "Not responding" message means nothing - just that the application hasn't picked up a mouse click or keypress (it may be busy doing something else).
Try getting everyone our of all Adagio/ACCPAC Plus modules and deleting EZSEMTAB.xxx in the data directory. See if that clears the problem.
#12175 - 04/09/08 02:49 PM Re: Vista hangups [Re: Retired_Guy]
You mentioned having SP1 for Vista. Is opportunistic locking enabled or disabled? I seem to recall that SP1 for Vista, and there is a bit of discussion on the forum here.
#12177 - 04/09/08 03:09 PM Re: Vista hangups [Re: Softrak Support]
Lizzy Offline
New Guy
There are no errors when we run chksys.exe and this checks to make sure that opportunistic locking is disabled, correct?
#12181 - 04/09/08 03:23 PM Re: Vista hangups [Re: Lizzy]
If you roll back SP1 from Vista, does the problem still exist?
