#11681 - 03/07/08 09:38 PM Adagio on Terminal Services - 64 bit server
Hello:
Chksys indicates 4 errors related to the 32-bit system status. This makes some sense since this Terminal Server is 64-bit.
The applications run 100% fine so far. Any cause for concern?
Thank you.
#11683 - 03/08/08 12:27 PM Re: Adagio on Terminal Services - 64 bit server [Re: Bruce Gardner]
You might have a problem with faxing from the terminal server.
#11689 - 03/08/08 10:41 PM Re: Adagio on Terminal Services - 64 bit server [Re: Retired_Guy]
Thank you Andrew:
They don't need to fax from the Terminal Server so that's OK. I will infer from your answer that Adagio will run properly on the 64-bit server despite the Chksys error.
#11690 - 03/09/08 12:18 PM Re: Adagio on Terminal Services - 64 bit server [Re: Bruce Gardner]
You should be fine with the general application.
0 registered (), 271 Guests and 1 Spider online.
14666 Topics
