#114 - 07/08/99 06:37 AM QRW 6.5 export options
I am presently using QRW to export info from a Peresoft product (TRAVPAC).
My customer requires the export as a "TAB SEPERATED TEXT FILE".
After the export, the fields are enclosed with the " character. Which he does not want!
Also if one of the fields was not captured, the export does not allow an empty space for that field.
I hope you can help!
Russell Fogg
#115 - 07/08/99 08:00 PM Re: QRW 6.5 export options
Hi Russell,
You are correct that in most export formats, the string values are surround by double-quotes. I did find that the export did leave spaces for blank fields, though, for the tab-separated text format.
If you want to perform an export with all fields separated by tabs, and not surrounded by double-quotes, you can do this in 2 steps. First, do the export in the character separated values format. This will allow you to export without the quotes. Unfortunately, you cannot have a tab as the separating character. What you should do is use a character that will not be in any of the fields, such as the tilde ~.
Next, open the export file in Word, and use the "Replace All" function to replace every ~ character with the special tab character (^T). This will create the export format your client requires.
[This message has been edited by Softrak Support (edited 07-30-99).]
1 registered (Carol Lord Openhym), 261 Guests and 5 Spiders online.
14625 Topics
